dougrainer
Jun 21, 2017Nomad
Bruce Brown wrote:dougrainer wrote:
Tiffin uses both LG and Panasonic(older Tiffins). There is NO remote programming. There is no fix, but when I test Tiffin systems, I do NOT point the remote anywhere but directly at the TV I am controlling. Even in the LR with the 2 TV's. Doug
When you do that, does it controll both TVs or just the one you're pointing at?
On our friends Allegro when he pointed directly at the bigger mid-mounted TV both TVs reacted. When he pointed directly at the smaller front mounted TV the mid-mounted one also reacted.
Both TV's do not react. I make sure it points directly at the TV. Also, remember, shiny surfaces in the RV can have the IR signal bounce off even when not pointing at the TV. What I don't get when people complain about this is, You have 2 TV's in the SAME ROOM area, WHY would you want to see 2 different channels in the same room at the same time. WHOSE volume are you going to use??????????????????? Doug
