Hello Everyone.....I started this thread months ago but realized I was too new to RV-ing so I spent the summer learning some things and only being able to run one of the two AC's at a time on shore power. Both run at once on the generator, but only one at a time on shore pwr. Have 2000 Rexhall with Gererac with two breakers on the generator, each for 30 amps...although the schematic says should be a 30 and a 20. Also have two switches one for front AC and one for the Back AC Inside the coach. Also have Intelletec EMU-2 with transfer switch etc.
I found the J-box with the two circuits running through it from the Generator and installed the Receptacle and pig tale as discussed earlier in this thread....
With the generator running, both AC's work at once via the two switches inside...unless I unplug the pigtail from the outlet, then the rear AC goes off as you would expect. The front AC continues to run and the RV still has 120 volts at the receptacles. But with the generator off, and shore power connected with the 30 amp cord, and an extension cord from 120 volts at the shore power post to the pigtail plug I installed... can only run one AC at a time no matter what position the two switches are in for the 2 AC's.
I think what I have missed here is that both AC's are controlled at the Intelletec EMU-2 and so I am going to have to modify what I have done with the Receptacle and pigtail I think and move this set up elsewhere in the circuit in order to bypass the Intellitec EMU-2. But I am now over my head trying to figure out where and how in the circuits to do this...
Can anyone offer me some help and advise in doing this in order to work with the Intelletec EMU-2...I have the schematic from the manufacturer if this would help...
Many Thanks...Ponder
