westom wrote:
Jim Norman wrote:
I have a Plug-In Surge Protector.
My new Coach has a built in Surge Protector.
Those are completely different devices for completely different anomalies (as a few have noted). A 'surge' addressed by a built in protector does not do and cannot protect from a type of surge that so plug-in protectors are suppose to protect from.
What does that plug-in protector do? It claims to 'absorb' how many joules? Hundreds or a thousand? That type of destructive surge can be hundreds of thousands of joules. So what happens when its near zero joules try to 'absorb' that energy? Those numbers should cause you pause.
If your built in protector was one that attaches at the pole, then it has a low impedance (ie less than 10 foot) connection to earth ground via that pole. If farther from earth ground, it does not effectively protect from that hundreds of thousands of joules. It only protects from those other anomalies.
An 'attach at the pole' built in protector would protect that power strip. Without a low impedance connection to earth, then that power strip remains at risk.
So what is the risk? A hundreds joule surge is routinely converted by electronics into rock stable, low DC voltages to safely power its semiconductors. What that power strip protector might do is already done better inside appliances. Sometimes, an adjacent plug-in protector can compromise better protection inside appliances.
In rare cases, a near zero protector (too few joules) can fail catastrophically (create fire). A cruise ship may confiscate it if found in luggage. Threat is rare but serious enough that many do not use plug-in protectors unless protected by that other 'connected low impedance to earth ground' protector.
Only answers tempered by numbers deserve attention. Read spec numbers for a built in protector to identify anomalies it addresses. Read spec numbers for that plug-in protector (especially joules) to identify the so little it really does. Take a $3 power strip. Add some ten cent protector parts. How much did you spend for that near zero protect function?
I am not sure that you saw my updated post regarding the SurgeGuard protector. If I am reading your post correctly you took me to mean I had a little power strip protector. I understand exactly where you are coming from. I plan on using my Primary, plug into the pole SurgeGuard in line with the on board unit, especially until I can confirm the on board units specifications. I do thank you for the clarifying post a there may be more than a few that would think a simple plug in power strip would do.
