JRscooby
Sep 07, 2019Explorer II
eHoefler wrote:
Governor for compressor bad.
Or more likely the little line to the governor was burnt by hot exhaust.
It won't hurt it, the high pressure pop off valve will release the air when over pressurized.
The pressure relief should dump pressure before damage, but he needs to hold the keyboard closer so I can be sure no other lines/valves have been weakened by heat. And pop-off valves don't always auto close before you have low pressure issues.
Not unsafe to drive, but needs to be repaired immediatly.
The air system is not likely to add danger of personal harm. But exhaust gasses venting into the living area is not good. And before I drove I would want to look around to be sure a fire was unlikely. Maybe make tin foil shields to protect lines/wires...
