You really need to determine if you have a water plumbing system leak. The easiest way to do that is to find out how to turn on your water pump. Put some water in your fresh water tank and turn on the water pump. The switch to turn on the pump is probably located near your level indicators that tell you how much fresh water, propane, and waste water you have in your tanks.
Make sure your faucets are all closed, then turn on your water pump. You might want to open the faucets until all the air is blown out of the lines. Then turn off the faucets.
If you have a leak, the pump will either run continuously or will turn on and off intermittently has the pressure leaks out.
The city water hooks into the same water system.
It's important that you find where the water is and open up all access hatches and get it dry in a hurry or you are going to have a mold/mildew problem.
Dehumidifiers are fine but you will have to empty the water holding tank for it periodically. I think fans will do you fine but you need to get them blowing into the compartments that got damp.
Steve
