Canadian_Rainbi
Jul 28, 2013Explorer
When you are sitting at the wheel with your foot on the throttle pedal is your lower leg still in line with your upper leg or is your knee tilted in or out?
Try a pad; folded towel, very small cushion, etc. under your right leg near the front edge of the seat. You may have to move it around a bit to find the right spot, or move your led a bit more left or right. Perhaps also a pad to help keep your leg in line.
Finding the right position should help a lot.
I had more discomfort in our Class A gasser, but find the DP much better. It is likely a positional thing aggravating your position.
Oh, and NOTHING in your pockets, front, back or sides!
Also as you seem to know, use the cruise control and much as possible and shift your position a little frequently.
A change of seat my well be the way to go, but how will you know it is the right one until you have driven in it for a while. It could get a bit pricy swapping seats!
Wish you success.
Wish you success.
38,769 PostsLatest Activity: Apr 24, 2002
