chuckbear wrote:
Thanks Tiger02, I will check that out. Dennis12, How do you find a transmission man you trust when you're traveling and a thousand miles from home in a place you've never been before? Chuck
It's nearly impossible except to read some online reviews, so I've made it a rule of sorts, to use a chain and so that if it gives us later trouble, we can take it somewhere else with the slip in hand.
Needed a rear differential seal in the boonies of TX once, so found a Chevy garage to replace it, rather than a local mom and pop place.
Something like buying at Walmart, if you will and certainly so if one should need to replace batteries while on the road.
