MrWizard
Jun 19, 2019Moderator
I ran the wiring for the pump
Pump is not yet installed
Bump in the road
Bundy fitting is correct length from ridge up to end of hitting
But...behind the ridge back to pump is not the same length as OEM FORD FITTING/nipple
Careful measuring shows not enough room to insert disconnect tool if pump is coupled to Ford fuel line quick connect fittings
Will have to go with plan B, and use pieces of fuel hose to connect system together
Bump in the road
38,782 PostsLatest Activity: Aug 31, 2026
