Pirate1
Jul 08, 2019Explorer
T18skyguy wrote:Ford tech warned me a while ago about the bolts said to make sure and pre-soak and turn forward/backward in small amounts.
My fuel pump went out and I used an ATV lift to bring down and raise the new tank. What happened is when I went to undo the bolts to remove the pump, every one of them snapped off which mandated a new tank. The guy I bought the tank from said that bolts snapping off is the single biggest problem with replacing the in tank pumps. You may have dodged an expensive bullet by not pulling the tank.
38,783 PostsLatest Activity: Sep 23, 2026
