MrWizard's avatar
MrWizard
Moderator
Jun 13, 2019
UPDATE - F53 external fuel pump install FINISHED
it has Ford size Male quick connect fittings
https://photos.app.goo.gl/ZotLkM6kCprK9s5S9
Inlet Attachement: Quick Connect
Inlet Size: 5/16 "
Item Grade: Standard Replacement
Maximum Amperage (A): 5.0
Maximum Free Flow Rate (gph): 28.0
Outlet Attachment: Quick Connect
Outlet Size: 5/16 "
Package Contents: Electric Fuel Pump, Terminal Hardware, Extra Fitting, Seal, (2) Retaining Clips, (2) Splices, Instruction Sheet
Product Condition: New
Pump Location: External
Pump Type: Electric
Relief Pressure (psi): 99.0
Strainer Included: No
Voltage Rating: 12 vDC
Wiring Harness Included: No
Working Pressure (psi): 44.0
RELATED ITEMS
REPAIR GUIDES
Repair Guides for your Vehicle See Details
hope to install this this Sat
$84.xx plus Tax
order online pickup in store..same day
got it from autozone, several other places have it online for less $$
but nobody was closer or faster
  • I'm curious, is there a place in the fuel line you can just slide it in? Or do you have some new fittings to splice in the fuel line?
    Richard
