rjstractor
Sep 01, 2015Nomad
tatest wrote:
You can find Load Range G tires with nearly the same diameter in 17.5 inch sizes, 215/75R17.5 specifically. These are not LT, they are commercial grade high mileage tires, usually designed for retreading. Rickson wheels has 17.5 inch steel wheel for this conversion on the E-series vans; I'm not sure who might have them for Chevrolet, this wheel size was used on the Kodiak/TopKick, but not on the vans.
The Kodiak actually used 19.5s, the 17.5 is a bit of an oddball size used mostly on some of the Japanese cabover trucks. Most of them now use 19.5s. According to Rickson's website they don't yet make the 17.5 wheels for the GM but will soon.
The posters who stated that upgrading your tires won't increase your overall capacity are completely correct. However, especially with the larger E450 and 4500 Express rigs, when at full load the rear tires are very close to their max capacity. Also, the wheel wells are pretty tight, which limits the amount of air circulation to keep the tires cool. Switching to the best tire you can find, whether you invest in the 17.5 wheels or not will go a long ways toward preventing tire trouble on the road.
