Davydd
Oct 06, 2014Explorer
You guys are confusing the issue. The OP has an Airstream Interstate Sprinter Class B van. Airstream still makes the Interstate Sprinter Class B van.
Option7,
You could visit an Airstream interstate dealer and ask them if they have a solution. But the first thing you can do is research the possible standard tank sizes, get a tape measure, look under your van where your propane tank is and determine yourself if you have the extra space to install a new, larger tank. If you think you do, then find someone that can do the work. It could be an Airstream dealer or it could be an RV service center with the capability. A tank is a tank. Just duplicate the connections you have that are outside the tank.
I would contact Airstream first. One thing you do have to consider is weight. You can investigate that yourself but Airstream might already have a ready answer for why they put in such a small size propane tank and also whether they had a larger option. You are dealing with weight limits and weight balance as well. If you have an NCV3 Sprinter model (6 cylinder) and only a 2500 chassis (4 wheels) the small tank might have been a concession Airstream made to build on that chassis initially. Everyone finally bit the bullet and went to the 3500 dually chassis. If you have a T1N chassis (5 cylinder models) it was also a 2500 but toward the end of that model run converters were pushing the weight limits on them as well.
Option7,
38,782 PostsLatest Activity: Sep 10, 2026
