Butch50
Feb 29, 2016Explorer
gbopp wrote:
It looks like a tight fit. But, you did a nice job.
I see a wire, is it heated?
Thanks,
It isn't as tight as you think. The chairs are quite wide so very comfortable. Chairs are over 22" wide, but yes the chairs just fit the space as there is only 57" width there. It took me a long time to find some chairs that would fit the space.
The wire you see is from the outlet that is behind the chairs. The outlet is wired for 120V shore power and also from the onboard inverter. I ran and short heavy extension so I would still have the use of the outlet. What you see plugged in is my battery tender for the chassis battery.
