ksg5000
Apr 09, 2016Explorer II
1980's Class C likely has a simple Converter rather than an Inverter or Converter/Inverter. A converter is the device which takes 120 volts and converts it into 12 volts - used to charge the house batteries and run various 12 volt devices (fridge, lights etc) in RV.
The older Converters are easy to upgrade and the new ones are quieter and tend to prolong the life of the batteries. Many upgrade to something like a Progressive Dynamics 9200 series - in my Class C I installed a 9245 which is a 45 amp version. You might consider calling Randy at BestConverter.com - he can provide free advice and is likely familiar with your current setup.
