hardtobe
Feb 13, 2014Explorer
gus33 wrote:
Look at a Curt #15901 or #15903. The side plates are not welded to the tube from the factory, that is done at installation. They can be adjusted to the width of your frame and the excess cut off.
I bolted mine on w/ 4 - 3/4" bolts per side. It has quite a bit of drop, & that is why we connected it to the engine cradle. If yours doesn't have much drop that may not be needed.
gus
that's why I suggested mine NO drop and he wants No drop.Its a solid one piece though so depends on his frame width.Need to hear from OP
I like mine because its all factory welding and painted properly
and wont rust
but if he has a different frame your hitch suggestions would most likely work
