Ivylog
Sep 10, 2016Explorer III
I run 5 psi over what the load tables call for... you are running 15 psi over on the front and rear from the load table pressures. You could use 11R/22.5 and still run the same pressures and you would still be 5 psi over what the load table call for.
I can only lead you to the water, I cannot make you drink it.
PS: a 11R22.5 is a very common truck tire making for really good prices and availability.
PSS: The GY 661 does not have a tire edge groove... decoupling groove which is also the problem with GY 670 wear problems.
38,782 PostsLatest Activity: Sep 02, 2026
