carp65 wrote:
We have a newly purchased 2015 Tiffin Allegro Open Road, 37',V-10.
Was wondering if we can operate on only 30 amp service if we are
very careful with our electric useage. Only one A/c at a time,
and don't run the toaster and coffee pot at the same time. Things
like that. We have so many power things--front night shade, awning,
two inside TV's, combo washer and dryer, etc. Appreciate any and
all comments
Not likely all this is going to be on at the same time, so no problem and as long as you're logical about usage. In addition, you can split your rear ac feed with a 20amp plug and outlet and not all that difficult for one with some electrical knowledge.
When plugged in, all is normal and when unplugged, it can then be plugged into a separate outlet on the pedestal to run the rear ac and leaving 30amps for the rest of the coach, including the front ac.
