timn's avatar
timn
4 years ago
Used class a ?
Ok the wife is retiring next summer. We travel now in a artic fox 990 slide in. We are getting older and need more comfort. I have been looking at several older used class a diesel pushers. We really want to keep our purchase price below 60000 $. I have found a pretty nice Dutch star 1999 model with 110000 miles on it. I just don't to have break downs on the road. Should I stay away from older mhs is it worth the risk. Thanks for your opinions.
  • Absolutely take your time and drive as many coaches as you can, this way you can determine which type of drivetrain will suit your needs best. As stated above, there are plenty of motorized RVs available on the current market, rushing to a decision, particularly with class A rigs, can turn into tens of thousands of dollars of repairs and huge losses in resale value. When buying an older motorhome there are so many details to research, sure floorplan is important, but overall condition and proper maintenance is critical to say the least.
    We just went through this process and looked at everything in our state, in the end we had to travel 1K miles to purchase our current rig. This was last summer while covid was raging through our great country, tried to line up inspections, unfortunately no RV inspectors were willing to take the job. Luckily owners let us stay 3 days in the RV and I was able to drive rig and verify operation of all major systems. We found the best deals were from private owners, we made sure to have money in place as RVs were selling days after being posted.
  • You should be able to find a late 2000’s (05-10) DP for $60k if you can come up a bit there will be more options. And definitely search a lot. You can find them with 50-100k for a really good price. And newer will be more powerful and more features.
    Good luck!
  • You need to look more. For $60,000 you can find a newer and less milegae diesel Rv. That said you find what you want and like and check it out. I did a quick search on RvTrader and come up with 2000 in your price range. Many other places to look also. Don't jump into buying.
  • Mine has 252k at the moment, and 7000 hrs on the gen. I have no hesitation about doing a loop of the country every year. Have the fluids analyzed on the oil, coolant, and transmission. Have a competent mechanic look it over. Be prepared to replace air bags, air conditioners, and appliances at that age. After all you would not buy a 20 yr old house and not expect to replace appliances and hvac equipment. The drivetrain is the most robust part of the motorhome. Look for signs of water ingress
  • jdc1's avatar
    jdc1
    Explorer II
    110k? Hmmmmm...... If it were a truck...okay. MH? Not so much. It probably towed a car behind it too.
