PghBob wrote:
If you consider a Super C unit, remember certain state like PA where I live will require you to get a Commerical Drivers License if the GVWR is 25000 pounds or more.
Good Luck with your search.
No state requires a CDL for a motorhome or other RV used for personal, noncommercial purposes. Some states do require a different class of non-commercial driver's license for motorhomes above certain weights and/or sizes (often mirroring the classes of CDLs); but that's not the same thing as a CDL, and carries different requirements--though often the written and road testing is quite similar.
Having a CDL requires one to undergo yearly physicals by a DOT certified physician, to submit to periodic random drug testing, to log driving hours (in most cases) and follow driving time limits, among other things.
