Ocean_Mist
Jun 23, 2017Explorer
jplante4 wrote:
Checklists are great if you know what you're looking at. Turn on the propane and smell around for gas isn't the best way to test the pressure in a propane system. Are you going to take the time to run the hot water heater until it comes up to temp, cycles off and back on? Have a thermometer to test the A/C and heater? How big a temp drop should you expect from a properly operating A/C? Are you going to send out an oil and tranny fluid sample and wait for the results? Are you going to paw through the Mx records to determine if the required PM items have been completed? These are things an inspector will do and is trained to look for. A proper pre-purchase inspection should take most of a day and the unit should be de-winterized and hooked up. If the dealer won't do that, I advise my customers to do a significant cash hold back subsequent to a satisfactory inspection. The dealer usually will find a water tap and a 120VAC outlet at that point.
The truth is, most buyers don't want an inspection because they don't want to be talked out of what is basically an impulse buy. I call it the Sgt. Schultz Syndrome - "I know Nutting, Nutting!"
That is so funny that you say that. I just realized that, the statement above is partially true for me, but mine is with a little twist.
I feel like I have had it inspected by professionals, and if there is any system that's not working, I will seek compensation from the inspection company.
If there are any issue during my inspection, I will try and re-negotiate with the seller.
And lastly, I feel like I will have to go thru every system on the coach and look over every aspect to make sure all systems are working order and in top condition.
It s a comforting feeling when one knows about any idiosyncrasies with ones rig...
I have jumped from a gasser to this DP and also feel like we have jumped a few baby steps to possibly our DP for life...?
i have an idea that I'll share with you once I own it... :h :B
Maybe not, I see a Prevost in my future...lol
