JCGibson
Jan 05, 2015Explorer
Used DP Reliability
In our quest for a Class A our options are a used DP that is about 6 years old or older or a newer gasser. What I would like to know if how the used DP reliability would be. I know it would depend on how maintenance was performed and how often, but even with that systems can and will fail. These items I am most concerned about since I don't have experience with them:
1. How long will the air suspension last before it starts to have problems and what maintenance is necessary?
2. Air brake system. How long do the shoes typically last and are they like the old days when cars had drum brakes and they have to be adjusted periodically, unlike disc brakes?
3. Does the air suspension and brakes use the same compressor system?
4. I am familiar with Cummins since we have one in our Dodge pickup, but what things are there to look for with a Cat engine?
5. Does anyone know if the Cummins in a Class A has the same or similar maintenance requirements as the pickup version?
6. What required maintenance is necessary for the transmission and is there anything to look out for?
7. I usually do most of my maintenance work, is the engine area easily accessible within reason?
8. Is there a chassis/owners manual that has recommended maintenance schedule?
9. Are parts readily available if something needs to be repaired?
10. Anything else I should be concerned with or need to watch for?
I know this is a quite lengthy list, but just want to be prepared.
Thanks everyone. You have been very helpful so far.
John
John
