Hi! Looking at a few used roadtreks, one is 92 roadtrek 210 independent. The other van is a 95 Dodge Ram 3500 V8 magnum. I've read a bit, but mostly I am still in the dark as to the quality of older...
If you read the FAQ's Sticky on the Class B home page you will see info. on the older Dodge vans. Some had handling problems that could never be corrected, and is one of the reason you will see some with low mileage. As long as you did a good test drive on a highway with trucks passing, and had no problems you should be good to go.
