wildmanbaker
Jun 09, 2014Explorer
Search for RV converters, and you will find quite a few in the 50 amp range for less that $200. These are 3 and or 4 stage converters, so over charging the batteries should end. Disconnect the charge output from your inverter, and use at 8 gage wire to connect the output of the new converter to the batteries and you should see less water loss.
38,771 PostsLatest Activity: Apr 19, 2026
