wa8yxm
Jun 09, 2014Explorer III
Step one: Go to the best converters web site (Add the usual pre/suffix you my need to delete the trailing "S" on converters)
Step two, Order a nice Progressive Dynamics upgrade kit for the Magnetek hunk o junk.
Step 2b, and a Trick-l-charge (if you do not have bi-directional isloator)
Step 3: Install the above
Step 4: Enjoy
Progressive Dyanmics makes a "Drop in" converter upgrade for hte Magnetek 6300, I forget it's model number, but basically it is a re-packaged 9200 series.
Top of the line, non better 3-stage converter (Several are either as good or very close but none better). NOTE this is designed for Flooded wet cells and not easily re-set to other types of battery.
Step 4: Enjoy
38,771 PostsLatest Activity: Apr 19, 2026
