Harvard
Oct 04, 2017Explorer
Do not forget to bypass and drain the Hot Water Tank. DO NOT put any pink stuff in the Hot Water Tank or the Fresh Water Tank.
Yes, you must do it between trips.
Also, keep in mind when you return from warmer climates in all likelihood you will need to dump your holding tanks before you head North. Why, because the CO dump stations may be closed during the off season.
