Photomike
Oct 05, 2017Explorer III
lfrese wrote:
Thanks RckyMtnVia! I wasnt paying attention to the forecast :( I will probably watch some youtube videos and figure out how to do it myself on Sunday.
Nobody mentioned using electrical tape on the pipes or the holding tank heaters. I guess those things arent too popular?
If you have a cold weather unit the water lines are already inside then using electrical tape is really not needed, in fact even for a unit that is not cold weather rated it takes a lot to freeze and cause any damage. I have mine in the cold (-10C) lots of time and all I do is to open the taps to release pressure and as long as it warms up the next day you will be fine. If you are unsure then turn the furnace on low and open the cupboards and run the hot water tank (if you keep water in it) before bed till it is hot.
Most, if not all, of the damage is caused by pipes that freeze hard then start to thaw but still have blockages of ice in the line then they refreeze again. When this happens the water that is refreezing is stuck and cannot expand down the pipe so it expands outwards thru the pipe causing it to burst. To have a hard freeze you need to have freezing temps for a couple of days and nights to get a hard freeze, one night will not do it unless we are talking -25C.
I was reading an article the other day about when to winterize and the writer put it perfectly "You need to winterize when daytime and evening temperatures stay below freezing" and I would add or when you do not have heat on during that time.
Yes air works, many people and places do use just air to blow out the lines of RV's and more for the winter. Just look at underground irrigation systems - blow out the water and you are done, no antifreeze in them. Problems will occur if you do not blow out all the water, then it settles and you can have freezing. I worked at a hotel that was only open in the summer, in the fall we would hook up the compressor and open all the taps for 20 or 30 minutes, flush the toilets till the flush box was as dry as you could get it and the water was out of the line, scoop out as much water as you could from the toilet bowl, add a cup of antifreeze to the flush box, toilet bowl and a half a cup to the sinks and shower drains and we were done. We would have a leak or two in the summer but most times it was from the person rushing or forgetting to open a tap.
Remember that draining water is harder in the winter when it is really cold and the water has started to freeze so if you are going to do that open your low point drains and pull the water heater plug on your way back home and let it drain out while the camper and tanks are still warm. Worst thing (not that I have done that)is to think you are going out and then it turns REALLY cold and you need to drain when the valves are frozen and the water is already slush.
