tarnold's avatar
tarnold
V 10 spins will not crank.
1997..first time ever will not crank. Usually just touch key and fires right off. Now leading up.. But don't see how this could be the problem. Drove up on some blocks to gain access to install new Hellwig sway bar. Where the L bracket on drivers side attaches on the inside of the frame there are two fuel lines going forward. Was very carefull in not disturbing them to attach top bolt on bracket. Got finished and tried to crank to drive off the lifting blocks. Just spins. Fuel pump fuse OK, removed passenger side panel to check emergency fuel shutoff, OK. Just noticed something else as trying all things, but I can shift the gear shift lever to any position and the starter will spin. I thought would only start in Park?? Old Fords had a shifter problem that you had to lift up on the shift lever to get to crank. Something is not allowing some sensor to not allow to crank. Other than unplugging fuel filter and turning over to see if fuel flow, how can I test fuel pump. Any and all ideas appreciated.
