Mike___Fran
Jul 20, 2014Explorer
V-10
Can anyone tell me for sure year Ford came with the higher horsepower engine. I think 07 or 08.
chadsdad01 wrote:
It was 2006. But a motorhome could be built on a 2005 chassis and be titled 2006. Double check the Vin number to make sure it is 362 HP vs 310. Free Vin decoders can be search on the internet.
dodge guy wrote:
And with the 3 valve engine you get the spark plug nightmare!
Ummm..Wrong.
Ford actually corrected the 'spark plug nightmare' (IIRC by adding more threads in the head) long before the 3 valve heads ever came out.
Its amazing, all the 'misinformation' that gets unknowingly spread sometimes.
Will
Hikerdogs wrote:
http://www.agcoauto.com/content/news/p2_articleid/120willald wrote:dodge guy wrote:
Ummm..Wrong.
Will
Actually there were 2 different problems with sparkplugs in the V10. The first and some of the second generation heads had only 4 threads to hold the plugs in place. Consequently some had problems with sparkplugs being blown out of the heads.
Some of the early 3rd generation engines had a problem with plugs breaking off when attempting to remove them. Sometimes when they got stuck over zealous mechanics just kept trying to turn them until thy broke in half. Ford published a specific method to be used when removing the plugs and a method to properly install them so they weren't over torqued.
https://kcss-transportation-technology.wikispaces.com/file/view/Ford+Spark+Plug+Problems++PDF.pdf
