Stuck_in_first's avatar
Oct 12, 2014
Velvac mirror
Need to replace the directional bulb in my velvac 2030 mirror passenger side. Its in the arm of the mirror. Anyone know how to replace the bulb. Don't want to disassemble the whole thing if I don't have to.
Thanks
  • hi Don
    Just finished up. Tested bulb,OK. check wire under dash, no ground. Abandon old and ran new one to nearest place. All works now
    Dennis
  • It looks like a lot of the wiring harness can be pulled out through that lamp opening. I'd pull out what you can, check the connections and power at the connection that goes to the bulb.
  • Thanks Don. Worked like a charm. I was hesitant to start prying not knowing how it was installed. Bulb was good. now on to the wiring.
