dangerruss
Dec 12, 2017Explorer
Vent Control
Trying to track down a vacuum leak that is causing the vents to default to the defrost position. I have good vacuum inside the engine compartment. I am ready to move onto the next step but need some help. I found where the vacuum line comes through the firewall. I proceeds to connect to a manifold of some type. I want to remove the black line from the bottom of this manifold to see if I have good vacuum or not but, I am not sure how to remove it. I hate to make the problem worse by breaking something. Any clues on how to remove the black line? Below is a link to some pictures.https://imgur.com/a/UFcRa
Thanks,
Russ
Thanks,
Russ
. You can see the black hose cut off where it comes out of the black cabinet and highlighted against that sliver of white. At least on a gasser, I would cut that hose, start the engine, and see if there's vacuum on the cut stub. There will probably NOT be vacuum there.
