Gjac
Feb 17, 2014Explorer III
I think you asked a good question especially when operating at 100-120 degrees. I would bring the genset to operating temperature then take readings with an IR temp gun in several locations including the eng block and generator housing. Then open the door and take readings at the same locations with the door open. I might even try it with a 12v fan in the compartment to see if moving air will reduce the temps.
38,782 PostsLatest Activity: Sep 19, 2026
