ksg5000
May 28, 2014Explorer II
A few more tips from a 92 Jamboree owner.
If your rig has original AC unit then it's likely the condenser and evaporator coils need a good cleaning - lots of threads on that subject. While your up their consider replacing both the start and run capacitors which are likely on their last legs - they are inexpensive. Some (including myself) replaced original start capacitor with Supco 6 Hard Start Capacitor which helped the aging AC unit start up - not very expensive and Supco techs are helpful in walking you through the "how to".
U tube has nice videos on how to remove your windows and replace the original butyl tape - not hard and you can do a few windows at a time. Start with the side windows in the cab-over bed.
These rigs came with lousy shocks and if you have the original they are really lousy by now. Bilstein shocks would be nice upgrade - makes driving much easier. Not a DIY as the front driver side shock is a real PIA even for someone who knows what they are doing.
Many report problems with exhaust manifolds - something to do with expansion issues between different metals. I never turn my rig off after long hard climb without giving the engine time to get back to normal temp --- something to consider.
If your fridge is the original - great - but it's likely nearing it's end of life so start a replacement fund.
Check all the chassis grounds ... that includes electric step, chassis and coach batteries and generator - grounds get corroded over time. Also - check out the auto reset circuit breakers - if original probably a good idea to replace or at least carry some spares.
Like YC1 - I park my rig with the nose elevated - inexpensive insurance for cabover water issues which are common in all Class C's.
Hope this helps.
Hope this helps.
