fisher60's avatar
fisher60
Vibration at 70 mph
This vibration started about 6 months ago and is slowly getting worse. I had an alignment done and the front tires re-balanced. No improvement. Yesterday I replaced the front tires and still no improvement. Could this be coming from the rear wheels? How many of you re-balance the rear duals at periodic intervals? Mine are just over three years old and have never been off. Any suggestion is welcome
  • Were the front tires spin balanced on the vehicle? that way you balance the whole system, brake drums/rotors, wheels and tires. Check for out of round tires/wheels.
  • othertonka wrote:
    while you are under the rig check for bad U Joints also. yes rear tires can also be out of balance and cause vibration. If fronts are out you usually feel it in the steering wheel. If rears are out, you usually feel it in the seat of your pants.
    This is definetly in the steering wheel
  • while you are under the rig check for bad U Joints also. yes rear tires can also be out of balance and cause vibration. If fronts are out you usually feel it in the steering wheel. If rears are out, you usually feel it in the seat of your pants.
  • enblethen wrote:
    It could be the center drive line support bearing.
    Hmmmm that's a thought. Going to drain & refill the differential here in a day or two and I'll take a look then. Thanks
