Chum_lee
Oct 15, 2019Explorer
K Charles wrote:
I'll second the drive shaft. I wish the kids around here were as good with their English, as a first language.
X3! Sounds like a center support or a U-joint. Crawl under the RV, put your hand on the drive shaft and shake it back and forth, then up and down at the front, in the center, then at the rear. Now you know where the problem(s) is. (the shaft will have play in it at the bad joint) Fix it now. It will only get worse until it fails and you are on the side of the road trying to locate whats left of your now bent up driveshaft.
Chum lee
