jsmart wrote:
I have 2006 Jayco Granite Ridge 2900, the vinyl molding on ours comes loose at the turn where the Ford cutaway van cab meets the overhand above the cab. I've just been tucking it back in after every trip.
I have nowhere to tuck mine in. It is about a one inch wide vinyl strip that is taped over the seam where the back cap meets the sidewall. The vinyl strip has two very narrow strips of two sided tape which sticks it to the surface, but the tape has weathered and lost its "stickiness" so it comes loose easily. Looking for a solution to re-stick it that is better than the standard foam two sided tape which doesn't hold up and is too wide to begin with. I am going to order some of the Eternabond two sided tape and give it a try unless someone has a better suggestion.
