rgatijnet1
May 08, 2018Explorer III
I believe that in 1993 your coach had a GVWR of 16,000 pounds. At 90 psi you should not have had any problems with the tires, at least due to under-inflation.
Assuming that you checked your tires with an ACCURATE tire gauge, I am guessing that you received defective tires or that you exceeded the speed rating of the tires which is probably 75MPH.
