wildtoad
May 08, 2018Explorer II
Sorry for the damage. You should have a placard somewhere in the mh that shows the tire pressure for your coach which is based on the tires that came with it and I suspect the GAWR. You should not need to exceed these numbers, but check the tire manufacturers chart. You should ignore the pressure on the sidewall, for the majority of folks you will never put that much air in.
I have read good reviews of your brand. Keep them clean and properly inflated.
