rgatijnet1
May 14, 2022Explorer III
Our biggest heat loss was the insulation in the front cap, above the windshield. Behind the cabinets the fiberglass insulation shifted and was basically useless. I bought some two part foam insulation and sprayed a thick layer of foam insulation on the entire front cap. Problem solved. Two part foam insulation kits are available on eBay. This also works for the same issue with the rear cap.
