wjschill's avatar
wjschill
Warm weather traveling
After traveling in a 35 foot fiver for many years, we have now started looking at class A gassers. We like to travel out west and southern locations.
My question...Do you need to run the roof a/c's while driving to keep the rv cool? If so, doesn't this mean running the genny and killing an already challenged gas mileage?
May sound like a dumb question...
Thanks
  • With my three class a's I have always ran the gen.,I start the motor then start the gen. unplug and off I go.
    The reason for me makes sense. The coach stays cool all the time, this way once stopped with no dash air the coach is already cool. I also like to keep the frig running on 120v with the gen. running my frig stays cold also. When stopping and want something warmed up to eat in the microwave its ready to go. Generators are made to run the little fuel they use to me is not worth it. But then I am not concerned about my fuel mileage. I have the coach to use if I get 5mpg or 50 mpg I am going to use the coach.
    Enjoy
  • We've had two Class A gas motorhomes. Never ran the generator and house a/c. We've run around the western States every summer for the past many years. The dash a/c has kept us cool enough. Point the vents right at you.
    When I have trouble is after we stop for the day. Very first thing I do is plug in to electric post and turn on the house a/c. Then I do the rest of the campsite setup outside, sweating, while the inside of the mh cools down.
    Thanks
    That's why diesel is better.
  • We have run the gen/set to get both A/C on full. The Newmar doesn't seem to mind.
    of course it uses fuel..
  • Hang a temporary curtain behind the driver/passenger seat.
    The chassis A/C will keep you cool.
    Thanks
    not dumb at all.
    - need? no, depends on how hot and when during the day you travel but it sure helps. we do.
    - yes to running the genny. yes to affecting the MPG but it's minimal.
  • My Onan 4000 is rated to use around half a gallon of fuel an hour at half load. My RV (28 ft class C) gets around 9.5mpg, so at 60mph running the generator would only lower my mileage by around 10%, which isn't a big strain on my travel budget.
    As long as I get going in the morning when it's cool and don't stop for long, I haven't needed to run the RV A/C to keep it cool, the chassis RV keeps the front cool enough. But if I stop and park in the sun for an hour, then I need to run the big AC for a while to cool things down. For me, warm weather means up to around the mid-90's.
  • Not a dumb question! Depending on the temperature you may need to run the ACs powered by the generator to maintain a comfortable temperature in the MH while driving.
