vcmoore304's avatar
vcmoore304
Washer/Dryer Door
Have a Splendide 2000 model WD802 Washer/Dryer which I understand is a discontinued model. For some reason the Door Glass "porthole" has crackled. Called Westland Sales but advised no more spare parts available. Find it hard to believe that even with a model upgrade that the door assembly would be radically modified and a new glass produced, however Westland were uncooperative to say the least. The outer Door molding has 148020690 and 148018428 stamped, the Inner 148018772. If anyone has any idea where I can get a new glass or even Door assembly I would be most gratefull as the Washer otherwise is in great shape being little used.
  • vcmoore304 wrote:
    Thank you all, appreciate your input. Many thank's to Dons 2346, called Kevin and a new door is on it's way !!!!!!
    Cool beans :C
  • did you check ebay yet? Often there is a lot of parts there.
  • Thank you all, appreciate your input. Many thank's to Dons 2346, called Kevin and a new door is on it's way !!!!!!
  • Call Kevin Waite at the below number. He has some 2000 series washers he is parting out. Excellent Country Coach tech also.
    Company
    K&M Mobile RV
    95430 Noraton Road, Junction City, OR 97448
    541-953-6162
    Email Address: kvn.wt.7629@gmail.com
  • Two thoughts... when I needed parts for my Splendide 2000s I had good luck with PPL Motorhomes who seems to carry a lot of parts. Could give them a try.
    You might also Google for some RV salvage yards and see if any of them have your door from a salvage.
    Salvage Yards has a listing by state though not sure how current.
