rgatijnet1
Oct 07, 2018Explorer III
dougrainer wrote:
I live in a city that has excellent water. How come my 24k pool gets algae(green and black)????? Unless I keep the water chemistry in balance with Chlorine and acid. I would never leave water in my RV. I have seen problems with water in the tank and especially the Water Heater, from mineral contents. IF you are not using good grade City water and filling from a well, you need to drain at all times you are not using the RV. I would fill if using good City water, but drain and refill once a month for those emergency trips. Doug
The water in my RV tanks is not exposed to the sun and the ultraviolet rays which quickly degrades the chemicals in your pool, which is why you have to add the various chemicals to keep things in balance.
