wolfe10
Jul 12, 2015Explorer
Yup, just buy a spare water pump (exact same model as in the coach will give you a spare).
Install it on a board and install 5' of hose with male hose connection on outlet side and female of inlet side. Wire positive and negative to cigarette plug. Install 12 VDC plug near the wet bay. If battery near wet bay, alligator clips work fine to power the pump.
If non-pressure water supply is a long ways off, use you regular hose to get to the pump/from the pump.
Been there, done that!
38,766 PostsLatest Activity: Jan 10, 2026
