Dutch_12078
Jul 12, 2015Explorer III
When I relocated the pump on our Landau, I added a 3-way valve to the pump inlet line, and about three feet of nylon reinforced hose. To add water from a jug or bucket to the fresh tank, all I do is turn the valve, open the existing fill valve, stick the hose in the jug and turn on the pump. To use the same setup for winterizing, just leave the fill valve closed and draw from an RV antifreeze jug to winterize the coach water lines without getting antifreeze in the fresh tank.
38,766 PostsLatest Activity: Jan 10, 2026
