sssoooExplorerMay 28, 2016water fillterjust got a "new to me" motorhome it has a 10" water filter what do you do when you winterize with antifre?ez
WyoTravelerExplorerMay 28, 2016If you do blow out your lines with air remove the housing and filter. All the water will not be blown out of the filter.
Related ContentWater PumpAtwood water heater problemWater tank won't fillWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???
