MountainAir05
Jul 28, 2013Explorer II
In general, flow rates for sediment filters are higher than for equally sized carbon or media filters. The tighter the filter, the slower the recommended flow rate is also a generalization you can count on. One manufacturer, for example, gives the following maximum flow rates for its pleated 9.75" X 2.5" filter cartridges:
1 Micron Absolute -- 3 gpm.
2 Micron Nominal -- 4 gpm.
5 Micron Nominal --7 gpm.
20 Micron Nominal -- 8 gpm.
50 Micron Nominal -- 10 gpm.
Carbon block cartridges in the same size are usually rated at a maximum flow rate of 1 gpm, and if serious chemical removal is expected, the flow recommendation would be slower.
so yes the filter can effect flow.
38,782 PostsLatest Activity: Sep 10, 2026
