SKIPCAROLExplorerJul 28, 2013water filter and pressure regulaterWe are at a campground with high water pressure and use a regulator (we always do)and a filter. By the time it gets to the tap, pressure is really low...if I take the filter off it's ok. Do you think...Show More
J_WalkerExplorerJul 28, 2013If you haven't done it already, place the filter before the regulator. Then their pressure drops do not add together.
Related Contentwater pressure regulaterTire Pressures8.1 Oil Pressure and FilterWater Regulaters in Motor HomeECOWISE Voltage regulater fault UPDATE
