SKIPCAROLExplorerJul 28, 2013water filter and pressure regulaterWe are at a campground with high water pressure and use a regulator (we always do)and a filter. By the time it gets to the tap, pressure is really low...if I take the filter off it's ok. Do you think...Show More
joeprinterExplorerJul 29, 2013Is the pressure just as bad with water pump only. Mine did this, an A Change of filter did the trick.
Related Contentwater pressure regulaterTire Pressures8.1 Oil Pressure and FilterWater Regulaters in Motor HomeECOWISE Voltage regulater fault UPDATE
