oldtrojan66
May 06, 2013Explorer
I would say it doesn't matter whether 12 or 120 volts. The element is possibly shorted to ground or through the water to ground. With electricity off (all of it, 12 and 120) take at least one wire off the element at the water heater and test for continuity from the element screw to the other one, then to the side of the tank. If there is a beep from one side of the element to the other, the element is good. If the beep is from one side to ground (the tank) it is shorted and this will pop a breaker. A partially open element where electric current is exposed to water will also sometimes cause a fuse or breaker to blow. hth
38,766 PostsLatest Activity: Jan 10, 2026
