Dutch_12078
Jan 30, 2015Explorer III
It might be the check valve on the hot outlet is a bit gummed up with mineral build up. If you can readily access the back of the tank, hold your hand on the check valve (looks like a coupling with an arrow on it) while someone runs some hot water. The check valve can be removed and soaked in vinegar or CRL to clean it up, or replaced.
38,771 PostsLatest Activity: Apr 15, 2026
