wa8yxm
Jan 30, 2015Explorer III
Check valves buzz at low flow, and I agree it is the check valve.
What kind of bypass do you have
Single valve, requires a check valve on the outlet. OR you can replace the check valve with a quarter turn
2 and 3 valve systems do NOT need check valves
Some companies put check valves on both the outlet and the inlet, why, I will never understand, but they do it.
38,771 PostsLatest Activity: Apr 15, 2026
